Turbo 350 10 tooth to 8 tooth drive gear
Old May 2, 2011 | 10:59 AM
habfan's Avatar
Car: 1947 ford
Engine: 350, vortec heads, TPI
Transmission: 350 turbo
Hi,
Would I be able to switch 10 tooth (Purple) to a 8 tooth (black) drive gear on a T350. It will have a 20 tooth driven gear. Tried to find information on line with no luck.
I need it for a 3.50 rearend gears and 28" tires.
Thanks,
Les H
Old May 2, 2011 | 11:12 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Turbo 350 10 tooth to 8 tooth drive gear
Maybe something here, though there is no 8 tooth:
http://www.transmissioncenter.net/sp...____va.htm#350
JamesC
Old May 2, 2011 | 04:50 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I've seen a lot of 7 tooth gears that were Purple.
Yes, you could run 8/20
7 and 9 are more common and I'd probably err towards something like a 9/22 combo.
Old May 3, 2011 | 04:47 PM
habfan's Avatar
Car: 1947 ford
Thanks for the help, I guess there is two different sizes 1.76" and 1.84" on the 20 teeth driven gear.
Les H
Old May 5, 2011 | 09:14 AM
habfan's Avatar
Car: 1947 ford
Does anyone know if a 2 speed power glide drive and driven speedometer gears will work on a turbo 350 tranny? The drive gear does fit on the shaft of the transmission.
Thanks,
Les H
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
camaro71633
Sep 1, 2015 10:24 AM
jharrison5
Aug 19, 2015 05:53 PM
milk
Aug 10, 2015 06:26 PM
