Tranny part swap from '90 700R4 case to '84 case?
The case cracked on my '90 700r4. It was in a 1992 4wd gmc k1500. I found another case but its from a '84 and its not a "k" case. It also has 27teeth on the input shaft (which i didn't know at the time I bought it and tried to install it). I believe it was for a v6 truck?
Can the swap be done if all the parts are still good and a rebuild kit is thrown in the mix?
Last edited by joshatmoody; Aug 19, 2018 at 05:06 PM. Reason: Add more to the title
Re: Tranny part swap from '90 700R4 case to '84 case?
With that said , in the Camaro/Firebird world our bellhousing bolt patterns are different between our V6 and V8 engines , now for your K1500 if I had to guess I'd say it's likely the same deal , V6 bellhousing not bolting up to V8 engine , but a truck forum is what you'll need for a certain answer ....
I just saw a new old stock 4WD 4L60E transmission for sale on this site. I will try to find it for you.
I searched for 2 hours. I can't find it.
Car: `86 SS / `87 SS
There are significant case differences between the 88+ and the early cases. This applies to trucks, and cars.
And of course, don't look at the 93+ trucks, and 94+ cars. Those are the 4L60-E, which are electronically solenoid controlled, and again, a different case.
Keep looking for an 88-92 case.
lonewolf583
LSX and LTX Parts
Oct 9, 2017 07:02 AM
thewizard
Exterior Parts for Sale
Jan 3, 2017 12:19 AM
cica55
Mar 31, 2001 02:46 PM
