Dana 44 axle removal
Old Oct 2, 2018 | 11:52 PM
charlie6178's Avatar
Car: 1992 Z28 1LE
Axle/Gears: SLP dana 44 3.92
I just got a Dana for my camaro and I went to pull the axles, I got all the backing plates off, retaining plates off, and everything ready. I put my slide hammer on the stud and give it some serious pull and it doesn't seem to want to move at all. I'm thinking about hitting it with some heat from an oxy acetylene torch and giving it some hits with the slide, but am I missing anything???
Old Oct 3, 2018 | 06:02 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Dana 44 axle removal
It's probably in there fairly decent. I'd keep at it with the slide hammer.
Old Oct 3, 2018 | 06:23 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Bigger slidehammer, no heat
Old Oct 3, 2018 | 11:25 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
sometimes they're stuck good if had to use a hammer on backside of axle to persuade them out there's no C-clips so you wont damage anything, sometime I've had to go though backing plate with a metal shaft that can be struck
Old Oct 3, 2018 | 10:45 PM
Car: 1992 Z28 1LE
Well.. the ol' BFH mod and a little heat from the torch and i got one side out. Going to try the other side tomorrow. I got it 203 degrees with my temp gun so I don't think I got it hot enough to hurt anything. I'm just glad one is out.
Old Oct 5, 2018 | 11:31 AM
Car: 1992 Z28 1LE
Got it! Now it's time to get the bearings off the axles so I can throw away the old brake parts, and get started cleaning the housing and prepping for paint.
Rpicard21
Oct 8, 2016 10:11 AM
FBODY-ADDICT
Jan 20, 2002 03:03 AM
Apeiron
Aug 11, 2001 08:08 PM
enigma57
Apr 12, 2001 08:50 PM
