Removing rear pinion shaft bolt.
Old Oct 24, 2018 | 10:52 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Whats the best way to remove the pinion shaft lock bolt on the diff without breaking it.? Should I apply some heat to it? They like to break.
Old Oct 25, 2018 | 06:39 AM
big gear head's Avatar
Re: Removing rear pinion shaft bolt.
They don't break when you are removing them, they brake during use. If you take it out and it's broke then it's been broke for a while.
Old Oct 25, 2018 | 06:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The info you require is in the following link:
https://www.thirdgen.org/forums/tran...ing-axles.html
JamesC
Old Oct 25, 2018 | 09:26 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have had good luck with using ONLY a 6 sided wrench and a sharp impact vs trying to turn it
Keoman
Aftermarket Product Review
Apr 14, 2013 09:39 AM
TomP
Aug 14, 2002 07:01 PM
AJ_92RS
Aug 12, 2002 12:18 PM
AJ_92RS
Mar 18, 2002 10:18 AM
BigRuss
Mar 15, 2002 05:17 PM
