1984 700r4
Old Oct 25, 2018 | 08:19 PM
Taft Barringer's Avatar
1984 700r4
Need some help badly. Did a carb swap and somehow it's like the torque converter has no stall at all anymore. Have to shift to neutral at red lights and stays engaged no matter the rpm.
Old Oct 25, 2018 | 08:48 PM
PaulyC's Avatar
Re: 1984 700r4
What is it idling at? Sounds like you might have either the idle adjustment too high or possibly a vacuum leak.
Old Oct 25, 2018 | 09:00 PM
Re: 1984 700r4
Idling at 1100. Swapped from the quadrajet to a holley street warrior 600cfm. Fast idle is about 2200 rpm.
Old Oct 25, 2018 | 09:16 PM
PaulyC's Avatar
Re: 1984 700r4
Yeah, that is a bit too high, you should aim for the 600-700 range. The carb may need some adjusting, there is a good Holley tuning sticky here just do a quick search. Another quick question, are you using a spread to square adapter?
Old Oct 25, 2018 | 09:28 PM
Re: 1984 700r4
Yes using an adapter. Plan on dropping a L33 with a 2 speed in it next month. Just tearing the driveway up with it acting like this. Is the lock up vacuum controlled? Could that be the culprit?
Old Oct 26, 2018 | 05:25 PM
PaulyC's Avatar
Re: 1984 700r4
The lockup is electrically controlled, if get your idle in the right area you will probably be fine.
Old Oct 26, 2018 | 05:39 PM
Re: 1984 700r4
Yes sir. You were right. Got that fixed and the brakes went out while test driving. Thank you sir.
firebirdta84
Jun 1, 2012 03:18 PM
3rdgenparts
Jul 18, 2011 12:56 AM
JFROG
Dec 31, 2006 08:22 AM
84TAProject
Apr 29, 2002 09:33 PM
