Better pan Gasket????
Old Jan 8, 2002 | 10:21 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Hello all
I am wondering if anyone out there makes a better gasket for the 700R4's pan. I have tried just about every manufacturer out there and the pan stays dry for about three days. Then you can see the fluid over the pan and the chassis. It's not a bad leak (no puddles after I park) but I would like to get that area dry so I could reapply some undercoating.
thanks
Old Jan 8, 2002 | 06:26 PM
86_Dan_Z28's Avatar
Car: 86 Z28
Go to Napa auto parts and get part no. 1-7936 filter kit. It comes with a nice rubber gasket. I never have problems with it leaking. The cheap cork gaskets that come with most filters are junk.
Old Jan 8, 2002 | 06:48 PM
82camaro's Avatar
Car: 82 camaro SC
Use a rubber gasket, clean both surfaces really well. Emery cloth works well to get a semi-rough surface--you don't want it too smooth. Make sure the pan is straight, hammer as needed to flatten. If it's too bent, get another pan. And then, DON'T overtorque the bolts--it will bend the pan and cause leaks. If you prep it right, it won't leak at all.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
