Removing pinion nut - Rear OUT of car
Old Dec 16, 2018 | 02:19 PM
Abubaca's Avatar
....so looks like I'm gonna need a new pinion seal on the used rear I recently picked up. Never actually replaced one before but it hardly looks difficult on paper. That being said, the rear is OUT of the car. Any thoughts on how to properly hold the yoke when breakin' off the nut?
Old Dec 16, 2018 | 02:27 PM
Drew's Avatar
Re: Removing pinion nut - Rear OUT of car
If it were a Ferrrd rear end, you could ram a Craftsman screw driver through one of the holes in the 'companion flange' to keep it from turning, then run over to SEARS and trade it in for a new one because now it's "right angled". Not that I have any experience with that.
Make yourself a tool to hold the flange. I've got the Ratech POS that bolts on and has 1/2" and 3/4" square drive holes for a breaker bar. Probably easier to get a piece of steel pipe about 3 foot long and some 1/4" scrap, drill to fit the U-bolt pattern, weld on the lever, good to go. You'll want something with some grunt for crushing pinion spacers at some point anyway.
Old Dec 16, 2018 | 02:31 PM
Drew's Avatar
https://www.summitracing.com/parts/RAT-18002/
Looks like Ratech has modded their tool since I bought mine... Mine was about the softest steel ever, and the holes were undersized for the application. Made it work eventually, but it was truly a piece of trash that was fit for Harbor Freight.
Old Dec 16, 2018 | 02:35 PM
Abubaca's Avatar
OK, I was thinking that I'd have to fab some sort of tool! Thanks! ....just wanted to make sure there wasn't something more obvious that I was missing!
Old Dec 16, 2018 | 03:00 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have a "custom" piece of 1"x1/4"x 3ft steel that I use for yoke holding when torqueing the pinion nut. It also works for removing the nut. I have 2 holes in it and a slight curved notch between them for socket clearance. Just bolt it tight to the yoke and go to town..
Old Dec 16, 2018 | 03:33 PM
Drew's Avatar
A little heat from a torch to soften the thread locker can help too, but you might not need to heat it up.
Old Dec 16, 2018 | 08:10 PM
Abubaca's Avatar
Awesome. Thanks guys.
Old Dec 16, 2018 | 09:29 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
I use a large monkey wrench, pipe wrench, plumber's wrench in or out of the vehicle. The jaws will chew up the yoke if you dont take precautions. If the handle doesn't hit the floor and stop I will put an additional jackstand under it.
Old Dec 17, 2018 | 09:15 AM
big gear head's Avatar
I used a large pipe wrench for many years before I made my tool for holding the yoke. Drilling holes in a piece of angle iron also works well. You will need a 1 1/4 inch socket for the nut. A good impact wrench will remove the nut without holding the yoke, but you will need something to hold it when installing the nut again.
Old Dec 17, 2018 | 09:33 AM
Dartht33bagger
Sep 29, 2016 03:16 PM
Keoman
Aftermarket Product Review
Apr 14, 2013 09:39 AM
hoogabooga
Apr 7, 2005 05:39 PM
wuter
Nov 25, 2003 08:05 PM
RJR99SS
Jul 3, 2003 06:55 PM
