tranny leak
Old Jan 8, 2002 | 05:24 PM
GeneralHazzard's Avatar
tranny leak
i got a tranny leak in my camaro. 700 R4
it aint terrible but its bad enough i gotta keep adding fluid every couple weeks. i thought it was that pan gasket when i first got the car so i changed the filter so it would give me a good excuse to put a new gasket that didnt fix it so i figured it was the dipstick tube, but when i got looking it dont look that way. its fluid up on top of the ledge of where the pan bolts but i cant see where its coming from. i can see its not the lines though. what else is up there that could be leaking? im at a loss here and i cant see a damn thing (damn tight spaces). anyway the car if parked for the winter so i figured now would be a good time and i figured maybe one off yall could get me headed the right direction. thanks in advance
Old Jan 9, 2002 | 09:54 PM
MotorCityMuscle's Avatar
Sounds like its the gasket between the TV cable housing and the transmission housing. Its a cheap seal, but a major PITA to install because you can't see it, only feel it.
Old Jan 11, 2002 | 07:01 PM
i was actually thinkin that was the only other thing that came out of the tranny. thats gonna be a real b!tch im sure.
thanks
Old Jan 13, 2002 | 10:22 AM
F-Body Fan's Avatar
Trans leak
I just had the same problem with my TH-350.It turned out to be the seal around the shifting linkage.
Mark_ZZ3
May 24, 2018 01:02 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Reid Fleming
Oct 10, 2015 09:56 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
