Crossfire and my TV cable
I have a 91' TBI Camaro that I'm swapping a fully ported ( yes I'm adding that little part so I don't get flamed
) Crossfire Injection setup into. So here's my question, what TV cable do I use? I don't have the original CFI cable ( it was a 200C anyway ) but I do have the correct bracket for the new intake. Will my old one work? Can I use the adjustment method I saw on here to get it adjusted right?
) Crossfire Injection setup into. So here's my question, what TV cable do I use? I don't have the original CFI cable ( it was a 200C anyway ) but I do have the correct bracket for the new intake. Will my old one work? Can I use the adjustment method I saw on here to get it adjusted right? I don't have a number for a cable but the best way to know if the TV is right is to have the pan off and have someone WOT the pedal (engine off of course!). Look at the TV linkage and when adjusted properly (yes the posted method works) the lever that pushes the plunger should be FULLY seated against the outer plunger sleeve. When released there should not be tension on the plunger. Sometimes the link is not the correct leangth and you can't get full travel on it too.
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
