9-Bolt M78 rebuild for under 300 dollars
Old Jun 8, 2019 | 11:34 PM
kenbob's Avatar
Car: 86 trans-am 1LE G92 WS.6
Engine: 305 LB9
Axle/Gears: 2.77 soon to have 3.45
Okay guys I did my own rebuild the only part I didn't do was set the ring and pinion. I did rebuild the posi myself I purchased the new oversized cones from Glenn at 9bolt.com for 132.00 USD. I then took the posi halves and ground down the inner raised ring portion flat. That allows much more room so the new cones don't bottom out from what Glenn and I discussed the m78 in the US is their 2nd generation they're now on there 4th gen solid diff 5th gen in our GTO/Holden I.R.S also called a M80 i.r.s parts from the M76/M77/M78 all are interchangeable. That means any car from Australia with a M76 M77 M78 ring and pinion will fit our cars and there are a lot the skyline GTR, the Ford turbo Falcon, all LS engine Holden's. So when people say that the 10 bolt is as strong as a 9 bolt they're sadly mistaken you can watch Australian Godzilla GTR's running 8 second quarter mile times in factory 9 bolt Nissan Skyline with a 2 SERIES CARRIER. So I said all that to say this it is well worth it if you are good with your hands to rebuild the 9-bolt and now there is a Detroit true track offered for the 9-bolt under 500 dollars. And easily installed. So if you can't afford an expensive diff roll up your sleeves and put in the work it's well worth it and if you have questions ask me or contact Glenn at 9-bolt.com he has been doing a bunch to upgrade his website since he took it over from the last guy
Old Jun 13, 2019 | 02:14 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Re: 9-Bolt M78 rebuild for under 300 dollars
Is 85w140 good to use in this rear? with the friction modifier...
Old Jun 13, 2019 | 08:36 PM
big gear head's Avatar
Torco is the best oil to use in the 9 bolt, but others work. Most of the time the additive is needed.
Old Jun 14, 2019 | 08:37 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Where can you source the Detroit truetrac in the US? It's not showing up in any search.
Old Jun 14, 2019 | 08:43 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
From others input here, you have to get it from Australia, it's not an ACTUAL Detroit/Eaton piece, it's just a helical gear diff
Old Jun 14, 2019 | 10:35 AM
GeneralDisorder's Avatar
Contact Dave at Supa-F Spares in Australia. He can get you one. You want the Torsen carrier for the Holden Commodore VL.
GD
Pilotrick50
Oct 10, 2016 08:02 AM
fsstnotch
Apr 10, 2014 11:27 AM
aohehir13
Sep 4, 2012 06:03 PM
AeroSS_87
Nov 9, 2007 06:59 AM
