Shifter cable for 4l80??
Old Sep 9, 2019 | 03:08 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Hey guys what shifter cables are most of you running for a 4l80 swap?? Are you able to get the stock cable to work or is aftermarket needed?? Thanks in advance
Old Sep 9, 2019 | 03:34 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Shifter cable for 4l80??
Not sure if the stock cable works or not, but I know the cable in the B&M console megashifter works.
Old Sep 10, 2019 | 01:57 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I used the shiftworks cable, but had to slot the stock bracket to move the cable forward. Shiftworks sells another bracket with more adjustability, but they were moving their shop when i called them and had everything packed up in boxes so i modified my stock one.
Old Sep 15, 2019 | 06:41 PM
thatsupnow's Avatar
Shiftworks huh?? I'll check them out
Yeah that's definitely the answer. They even come with new brackets and levers for the 4l80
I_R_O_C_Z_2_8
Sep 13, 2019 11:32 PM
micknick1
Feb 27, 2012 04:13 PM
