Diff cover magnet grey sludge. issue?
Old Sep 18, 2019 | 07:27 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
working on my rear disk brake swap, there is a layer of grey sludge on diff cover magnet. pretty much covered the magnet. how much is too much?
Old Sep 18, 2019 | 10:09 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Re: Diff cover magnet grey sludge. issue?
why did you pull the magnet? Are you going to replace the fluid?
It's pretty common. Unless it seems to build at an alarming rate or seems like chunks instead of just fine metal shavings... I wouldn't get worried too much. As long as the diff still acts normal, sounds normal, seems normal, then its probably 'normal'. Hard to judge without a picture but I would suspect everything is fine because you aren't like "I found a chunk of metal" or whatever the post-mortem question phrasing
Old Sep 18, 2019 | 11:52 PM
LiquidBlue's Avatar
Transmission: MD8
diff is from 1991 camaro super car. don’t know mileage. refreshing it before it is installed into my 90.
Old Sep 19, 2019 | 01:08 AM
NoEmissions84TA's Avatar
Don't sweat it. It's most likely normal. Unless the glob is the size of a golf ball.........
MARO-MAN
Dec 17, 2006 11:35 PM
rjpbboi
Nov 30, 2005 04:21 PM
MrJ
Feb 19, 2003 06:35 AM
