Differential hot tank cleanup options
Old Sep 19, 2019 | 10:14 AM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
Any of you guys had any luck bringing a diff to a machine shop and have it cleaned up? Does this hurt the bearing races? Is it worth it? What did you have done? Can they bring it down to bare metal so it is ready for paint? Is it worth messing with axle shafts too? Thx in advance.
Old Sep 19, 2019 | 11:58 AM
Re: Differential hot tank cleanup options
If it gets to that point, you'll be replacing all the bearing races anyway. No need to worry about them.
I get them sandblasted, tubes welded up, lower control arm relocation brackets installed, and powder-coated.
Old Sep 19, 2019 | 12:07 PM
LiquidBlue's Avatar
Transmission: MD8
What I'm after is to have someone clean them up so I can paint. Basically don't want to do all that dirty work, very time consuming and can't do it as well as they can anyway. But don't really want to replace bearing races - shouldn't they be matched with new bearings?
Old Sep 19, 2019 | 01:46 PM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
It probably negates your lack of wanting to do it, (and I completely don’t blame you lol) but a wire wheel can do a nice cleanup on these in prep for a finish paint. A friend did one years back and I was quite impressed with how well it looked after.
Old Sep 19, 2019 | 03:29 PM
LiquidBlue's Avatar
Transmission: MD8
well, made a few phone calls and know one seems to have a hot tank that big. one place wants $1200 to put in new bearings/races and put it back together so everything is set up right.
Agent13
Southern California Area
Mar 28, 2017 01:27 PM
Sonix
Mar 7, 2008 11:28 AM
Stratocaster
Aug 6, 2007 04:19 PM
1 DwnCam
Aftermarket Vendor Review
Nov 27, 2006 10:28 AM
purg3d
May 29, 2006 08:59 AM
