Shake
Old Sep 19, 2019 | 10:30 AM
GL'sFireChicken's Avatar
Shake
I did a 305 to 350 swap, an auto to t5, and swappped in a 9 bolt, when I'm driving at 45 to 50 in 5th the car gets a really bad shake almost like its lugging but more exaggerated, I did a trans mount and a u-joint but it's still there what else could cause this? At speeds like 65 or 70 the shake goes away
Old Sep 19, 2019 | 02:03 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Shake
Bent axle shaft? Warped disc? Worn bearings?
Old Sep 19, 2019 | 07:22 PM
Re: Shake
I think bearing would be the most likely, which ones do you mean @Base91
musclecar70sfan
Feb 28, 2014 05:57 PM
CBOYER
Oct 11, 2013 06:47 AM
sewerrat
Dec 8, 2008 11:47 AM
Jproz1167
Mar 31, 2003 12:46 PM
