10 Bolt gear oil recommendations
Old Oct 25, 2019 | 06:23 PM
Red86SS's Avatar
Car: 1986 Camaro Z28
Engine: '80-'84 2 bolt 305, 58cc heads, FBO
Transmission: 1990 700R4 w/shift kit & 2-4 servo
Axle/Gears: 3.73 Posi (GT4 G80)
What weight of gear oil should i use in my 3.73s after my break in period? I'll be driving 65 fairly often and don't want it to get too hot. It doesn't get hot at all right now though, I have a T/A Performance diff cover to try and dissipate all the heat it can. I still have about 200-300 miles until I feel safe doing anything other than cruising around for a bit then stopping to let it cool off. Its starting to get cold here in Kansas so hopefully that will help keep it cool
Old Oct 25, 2019 | 07:51 PM
Re: 10 Bolt gear oil recommendations
75W-90 Mobil 1
Why so slow? I hope not TOO often? I just HATE IT when people do that in front of me, except of course in school zones. At such low speeds, very little stress is applied to anything in the drive train, beyond the weight of the car and the mere fact of rolling.
Old Oct 26, 2019 | 03:19 AM
Red86SS's Avatar
65 isnt that slow to me. I live on the highway and it's several miles to town is the only reason i'm asking. Thanks for the input!
Old Oct 26, 2019 | 01:55 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
i run royal purple 75/90 and throw in some additive even though they say you dont need to
Old Oct 26, 2019 | 01:58 PM
I live in a minor city (2 or 2½ million people; quite small and quaint really) and people do that down the 1½ lane wide street in front of my house. They go AT LEAST 85 or 90 on the freeway; gotta be careful ya know, can't get too carried away, it's curvy and hilly and there's entrance & exit ramps all over the place, not to mention Grandma white-knuckling it down the middle lane in her minivan at whatever laughable speed limit they post. Which about the only vehicles that go THAT slow are 18-wheelers when it's icy. Good thing I don't live out West or on the Great Plains like you, I'd get RUN OVER if I was doing only 65 on just about any public road.
Seriously though, Mobil 75W-90. Then, if you have a clutch-type posi, a unit of the GM "whale c**" additive before the lube. It'll be fine. If you have a 9-bolt, it's got cast-iron clutches and the additive has no effect; or, if you have a stock (Auburn) posi, it's a total POS and doesn't really do anything anyway because it's a POS and has already failed and wore out, and it doesn't matter what you put in it. Or, if you have a Torsen or True-Track, it's all gears (no clutches at all of any kind), and doesn't need the additive either. Or, if you have a Gov-Bomb aka Grenade-Lock, it won't matter what you put in it, it'll EXPLODE SPECTACULARLY when you least expect it, and hopefully the red-hot shrapnel it produces when it does, won't penetrate all the way through the diff cover AND the gas tank and make your car explode. But if you have a REAL ACTUAL posi with composition clutches, such as an Eaton or Yukon, the additive will help it work smoothly without chattering or groaning or wheel-hopping around sharp turns or any of the rest of that.
91banditt2
Oct 7, 2019 10:31 PM
91banditt2
Oct 7, 2019 11:40 AM
MachinistMark
Jul 15, 2016 11:20 PM
stingerssx
Jun 25, 2005 09:17 AM
Night rider327
Sep 30, 2004 07:49 AM
