Vibration issues
Vibration issues
I have this issue with my 1982 firebird, and it stumped me. When I drive, I have consistent vibrations that I can feel while sitting in the car. They're most noticable around console area, so I thought it might be an issue with the transmission and driveshaft or some sort of linkage between them. I figured there are many people on hear who have way more experience than I do, so if someone could point me in a direction as to what might be causing the problem, that would be much appreciated.
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
Re: Vibration issues
I can tell you I had the same issue with mine when it was all stock, I changed out the 200c transmission to a 700r4 and installed an aluminum driveshaft and the vibrations went away and was smooth as butter going down the road, I don't know which caused it for sure but easy enough to locate an aluminum driveshaft from a 3rd or 4th gen car and try that first, but upgrading to overdrive is a must if any highway driving imo.
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
I was thinking it was the u-joints, but I never thought much about the motor or transmission mounts. What should I look for when examining them and what sort of wear should I be on the lookout for? I'm not a master mechanic of any sort, so simple terms would help a ton.
Car: 1986 IROC Z
Engine: 5.0 TPI
Engine mounts can be checked by observing the engine for upward motion when you apply the brakes and give the engine some gas while in gear. Use caution here.
Unless a u-joint is totally trashed, the driveshaft usually has to be removed in order to check them. Look for obvious play or roughness as you move the joints through their range of motion by hand. Additionally, a locked-up joint will require replacement.
