My 3rd gen z28 1984 mode with th400-r4 leek transmisdion oil true the seal on the gear shaft seal
how to idenfify the correct part i need,
i assume i have to drain all the oil .
i then will replce .
seal on shiftet shaft
outgoing shaft from tramsmission
and spesial tools for these jobs.
please help me out.
i do live i Norway andthere is no workshop for these car in my region.
please help me out.
jmd
close
- Join DateJul 2000
- LocationAridzona
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car`86 SS / `87 SS
- EngineL69 w/ TPI on top / 305 4bbl
- Transmission`95 T56 \ `88 200-4R
- Liked:94 Times in 91 Posts
Look for a shift shaft seal tool. It will help you change the seal without transmission disassembly.
I usually remove the pan and remove the manual shaft to replace the seal. Once the shaft is out of the way, I pry the seal out and use a socket and hammer to install the new seal into the case. The attachment shows the procedure.
Here's a link to some seal part numbers. Hopefully, you can buy these in Norway. Buy a few of them in case you happen to damage on during installation:
https://www.rockauto.com/en/catalog/...haft+seal,8648
Here's an example of a tool that's made to replace the seal without having to drop the pan. I've never use such a tool::
https://www.classictransmissionsolut...elector-shaft/
