drive shaft seal?
Old May 31, 2005 | 09:14 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
drive shaft seal?
the seal on the end of the tail shaft that seals the end of the drive shaft. Can this seal simply be pulled with a seal puller like what would be used on the timing cover balancer seal? And then a new one punched on w/ a block of wood?
Old May 31, 2005 | 09:30 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Yes, you sure can.
Sort of. The only thing that makes replacing that seal at all hard is getting the new one installed. Since the output shaft sticks out further than the seal, you can't use just a plain block of wood. There is a special tool to install that seal, but I have seen many people install them by hammering the new seal in with either a block of wood with a large hole in the center for the output shaft to run through, or by using a large socket to hammer the seal in.
It will be fairly straightforward what to do once you get the driveshaft off. Good luck.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
