What trans is in my 86
Old Jan 13, 2002 | 02:32 PM
84SportCoupe's Avatar
I was wondering what transmission is in a 1098 camaro with a 2.8? It is an od trans. is it a 2004r or a 700? I am putting a v8 in so will a 700 bolt right up to the torque arm???
Old Jan 13, 2002 | 06:52 PM
transfixleo's Avatar
That is a 700 but it has a different bellhousing than the V-8.
Old Jan 13, 2002 | 06:56 PM
So will a 700R-4 with a V-8 bellhousing bolt right in???
Old Jan 13, 2002 | 06:59 PM
ChevyRacer83's Avatar
If you look at your shifter column and the gears say 1...2...3...D..then a D with a circle around it, it's should be a 700R4. As far as hooking it up to a V8 I think the bellhousing are a different size so it wouldn't fit.
Old Jan 13, 2002 | 07:01 PM
What I mean is that if i get a 700 with a V* bellhousing the torque arm and all will bolt right up
Old Jan 14, 2002 | 03:38 AM
Yes. The nice thing is that with the 2.8 you will have 3.42 gears!
Old Jan 14, 2002 | 10:54 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
You can use any v8 or 4.3 v6 700r4. You can change the tail housing from your 2.8 tranny. When you do change the gear on the tail shaft to your new tranny. That way your speedo will be correct. Cheers.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
