700r4 speedo gear housing leak.
Old Mar 8, 2020 | 12:05 PM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
I have a leak from the speedo gear housing I believe. This is what it looks like from underneath. What needs to be replaced, is there just a seal inside the speedo gear housing that needs to be replaced. Any help would be great thanks.
Old Mar 8, 2020 | 12:13 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 700r4 speedo gear housing leak.
There is a o-ring on the Vss.
Old Mar 8, 2020 | 12:18 PM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
Hey Brian, ok so is it just a 10mm bolt that holds it in. Thanks so much for the reply
Old Mar 8, 2020 | 01:13 PM
Engine: Lb9
Transmission: M20
It is just the one bolt and the hold down that retains the Vss.
im not sure what size the o-ring is I think it’s 2” od.
maybe some one else will chime in. You might have to pry out the Vss the o-rings can swell and make it hard to remove.
Old Mar 8, 2020 | 01:36 PM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
Can the outer part of the vss be leaking too (I don't know the correct name for it). As you can see there are two drips one on the outer part and one on the inner part where the o ring is. If I put a new o ring on and the outer part still leaks do I need a new vss?
Old Mar 8, 2020 | 01:55 PM
Engine: Lb9
Transmission: M20
Yes the outer part of the Vss can leak. Depending on the gear count of your Vss I might have a new one if needed.
the cheapest would be to do a o ring first then Vss if needed.
Old Mar 8, 2020 | 02:29 PM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
Ok thanks, next weekend I'm gonna do the job and I'll just do the o-ring first, then if its still leaking I will PM you for the vss. Also if your vss doesn't fit my application where can I obtain a new one that will fit. Thanks so much for the help.
Old Mar 8, 2020 | 02:56 PM
Engine: Lb9
Transmission: M20
RockAuto has the Vss but doesn’t list the o ring separate
Old Mar 8, 2020 | 03:09 PM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
Ok thanks I found one at a decent price if I need it. Thanks again.
LiquidBlue
Aug 16, 2019 09:12 PM
gill9228
May 27, 2012 09:04 PM
blackblazer717
Mar 21, 2008 09:45 PM
bjquiroz
Jan 9, 2002 05:35 PM
