TH200C adjust kickdown cable
Old Apr 25, 2020 | 06:09 PM
82Firebird5.0's Avatar
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Axle/Gears: 2.73 open diff
I can’t find anything anywhere about how to do it, found the cable but there’s no adjustment mechanism that I can see... Can anybody help?
Old Apr 25, 2020 | 06:34 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: TH200C adjust kickdown cable
Lots of discussion on this has been gone over. Here's one:
https://www.thirdgen.org/forums/tran...ressing-2.html
Your 1982 will have the same cable as the Quadrajet applications with 200-4R and 700-R4 through 1987.
Old Apr 25, 2020 | 08:18 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Got this from my tran guy. There are other ways but unless you have xray vision, you need to see where the plunger is. It also will confirm if your geometry is correct based on how far the plunger moves.
Old Apr 26, 2020 | 12:21 AM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
i have to remove the pan? I thought there was something I could adjust externally for tension. This will be a lot more work than I thought. The trans doesn’t always shift down like it should, and tries to pull 3rd at low speeds
blue85305
May 22, 2007 01:03 PM
alli89
Jan 18, 2005 08:30 AM
Nixon1
Nov 8, 2002 06:24 PM
