Stator shaft teflon seal tool use
Old May 1, 2020 | 09:18 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Axle/Gears: 3:42 open diff
I’m having trouble figuring out how to use this new Teflon seal tool for the stator shaft,
here are some pics
Old May 2, 2020 | 05:28 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Stator shaft teflon seal tool use
The tapered tool on the right is sitting on a screw in "plunger". You thread the plunger up inside the tapered tool.
You slide the whole thing over the stator shaft and adjust the plunger so that the end of the tapered tool sits just above the groove where you want the seal ring to sit.
Start at the bottom groove and work towards the end of the shaft. Lube up the taper and the seal ring and start it over the taper tool. Use the fingered tool to push the seal rings down over the tapered tool and into the groove.
Screw in the plunger (which raises the taper tool) and line up the next groove and repeat until all the seal rings are installed. The seal rings will be stretched out.
There should be a hat looking resetting tool. Identify the tapered end of the inside diameter and slide this end over the seal rings to reset them. Let it reset for ~24 hours.
Old May 2, 2020 | 11:51 AM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Ok thank you so much for the in-depth detail!!!
Dholland17
Aug 27, 2019 09:34 PM
tpi90rs
Aug 25, 2009 09:07 PM
n8sz28
Jun 29, 2008 08:00 AM
SMURFN' Z28
May 31, 2005 09:30 AM
fly89gta
Aug 18, 2001 01:21 PM
