HELP! Transmission Car Just Started Doing Something Strange. Videos inside
Old May 19, 2020 | 10:45 PM
Vinscully50's Avatar
Car: 1986 Camaro IROC Z
Engine: LB9 305 TPI
My 1986 Camaro IROC Z TPI 700R4 just started doing something strange. It's been driving fine. I drove for about 30 minutes earlier today with no problem. Another short trip to the gas station no issues.
Tonight I took it for a 10 minute drive. I was driving at 60 no problems. I stopped for a light and made a right hand turn. WHen I began accelerating my car began revving to 3500 RPM and it started making all kinds of funny noises. It seems to shift really hard into 2nd and 3rd and it's not going into 4th. In overdrive it's shifting at 3500 RPM. The car feels like it has no power.
Transmission was rebuilt 4 years ago from a very reputable shop. It was given an upgrade with thicker clutch packs. Rear end was rebuilt just a few months ago. When my transmission died the last time it neutral-ed out in 4th gear but ran fine in Drive though it wanted to overheat. This time it's revving really high and the car feels like it has no power.
In idle the car seems fine. I'm afraid driving like this I am going to blow my engine. Here are the videos:
Please let me know ASAP. That way I can have this car towed. I'll try to get videos in the daylight if I can.
Old May 19, 2020 | 11:06 PM
Engine: LB9 305 TPI
Re: HELP! Transmission Car Just Started Doing Something Strange. Videos inside
I went back out for another quick drive. Here is a better video of what is happening.
I Checked the dipstick. Fluid level is fine. There is water dripping from the center of the car near the transmission and it is water not transmission fluid. I'm not sure where that would even come from.
Old May 20, 2020 | 10:52 AM
Engine: LB9 305 TPI
Update I took it for a drive this morning and the 700R4 won't shift out of first. The RPM drop is me letting off the gas not the car shifitng. I couldn't get past 20 mph or so and the engine just keeps revving without shifting.
Old May 20, 2020 | 05:39 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Well, in my unprofessional opinion, you need a rebuild.
Maybe something to do with the pump which is making the noise.
Not getting out of 1st, and the other issues you describe could be related to the throttle valve, or maybe the TV cable is broke. You can try TV reset procedure, but I don't think thats the problem when you also count the noise it seems to be making.
TV Cable mis-adjusted can cause all sorts of drivability issues, in addition to a quick death. If the actual throttle valve in the valve body is stuck or or not working.
I'm sure someone with more experience will come along.
Old May 20, 2020 | 08:29 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Assuming the TV cable adjustment is correct, the first place I would look is the governor.
OT - what's up with your battery voltage?
Old May 20, 2020 | 10:49 PM
Engine: LB9 305 TPI
If this needs a rebuild, I am beyond pissed that this transmission only lasted 4 years. I've only put 20,000 or miles on it since the rebuild. It started making a ton of noise last night out of the blue. Earlier that day it was quiet. This car has never been raced and I don't do burnouts either. It's suppose to be stronger than stock too.
What would cause the TV Cable to become misadjusted? Does it just become misadjusted over time? The last time it was adjusted was when the transmission was rebuilt. Hasn't been touched since.
Old May 20, 2020 | 10:58 PM
Engine: LB9 305 TPI
As far as I know the TV cable is correct. It hasn't been touched since the transmission was rebuilt. It doesn't come misadjusted on it's own right? Is it normal after 4 years or so and 20,000 or thousand miles for a TV cable to come misadjusted?
I'm going to call my transmission shop tomorrow and have them look at. I'm hoping it's just the governor.
The transmission shop is very reputable, I know every auto repair shop in the area uses them as does almost everyone. The father and son are 700R4/4L60e specialists. They told me they installed thicker clutch packs, a better piston and made some adjustments so the transmission runs cooler.
As for the voltage meter, the needle is stuck. A year a go, I taped cardboard behind all three of the gauges because the needles kept sticking after I would shut the car off. But a few weeks ago when it got hot all of the tape melted and the cardboard shifted. Temp and Gas the cardboard shifted up so the needles still aren't sticking but I guess voltage it shifted down so now the needle is stuck behind the face plate.
Old May 20, 2020 | 11:37 PM
Engine: LB9 305 TPI
I found the RO for the transmission rebuild. I have less than 20K on the transmission. I've only put 16,600 miles on the rebuild.
Old Jul 13, 2020 | 05:22 PM
Fbodygraveyard's Avatar
Car: 07 superbee ,72 charger,64 300k ,38
Engine: 6.1 hemi,340 Magnum ,413 Dodge ,350
Transmission: Alot
Axle/Gears: Alot
Sounds like your internal pressure s are off something might be blocking flow .
in other words a bad rebuild it happens hopefully the shop will make good buy after 16k I'd say probably not unless they give warranty
Old Jul 13, 2020 | 05:46 PM
Engine: LB9 305 TPI
It ended up being the Governor. They did for free under warranty.
Chris Knight
Jul 2, 2019 02:54 PM
1991formula305
Nov 9, 2017 11:55 AM
slow_90firebird
Mar 3, 2009 11:20 PM
83camaroMN
Feb 17, 2008 06:00 PM
ZZ4 86 Z28
Oct 24, 2005 10:20 PM
