3rd gen and 4th gen rears,,,,elighten me
Old May 22, 2020 | 07:54 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Can I put a 4th gen carrier into a 3rd gen (10 bolt and 10 bolt)...axle spline the same/...etc. I have a 4th gen rear and see it's a c-clip axle...are 3rd gen 10 b0olts as well?
I snagged the 4th gen rear because it has a 3 series carrier in it, and I want tio deepen up the gears on my kids car, if carriers won't swap, I'll go through the 4th gen rear with a new gear set and run it.
Edit:
The 4th gen rear is from a '94
Old May 23, 2020 | 07:25 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: 3rd gen and 4th gen rears,,,,elighten me
Edit:
There are two things I know for certain ;
#1 , the 4th gen rear is slightly wider than the 3rd gen unit , by something like an inch on each side . While it will physically bolt in , the tires will stick out an inch further on each side .
#2 , up till around 1989 , the axles were 26 spline , and then in around 1990 they went to 28 spline .
Other more informed TGO members will have to tell you whether the carriers will interchange or not , were I forced to guess I'd guess they will , but I can't say that for certain .....
a mack6
Nov 26, 2018 07:09 PM
Duane's 91 Z/28
Northern California
Apr 28, 2011 12:02 AM
carloracer1987
Aug 5, 2008 09:25 PM
Flounder87
Nov 29, 2007 07:50 PM
