How to tell if rear-end out of Camaro has POSI??
Old Jan 14, 2002 | 05:27 PM
smoke the tires's Avatar
HI-
I am going to look at a rear end out of an 1985 Camaro Z-28 HO that has supposedly had 3.73's and posi installed in it not too long ago. How can I tell this unit has posi? It is still in the car but it is not running.. I was told if I jacked the car up and put it in neutral and rotated the tires both should move the same way. Is this true? Or if i took off the axle cover should I be able to see anything that would give it away being a POSI and having 3.73's??
Thanks in advance for any help and information,
Dan
Old Jan 14, 2002 | 06:22 PM
Ezey Go's Avatar
Yes, if its posi both tires should turn.If you take the cover off look inside the case (posi unit) and if there are springs in it then it is a posi.
Old Jan 14, 2002 | 07:49 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yea, the best way is to have a buddy hold the other tire then spin the one your on and they will both start to spin in the same direction. If you were to just spin one tire the other might not even move due to the limited slip that keeps the rear end on the ground when you turn corners.
SSC)
Old Jan 14, 2002 | 10:38 PM
82camaro's Avatar
Car: 82 camaro SC
Put it in gear and try to spin one of the rear tires. If it spins free and the other wheel spins the opposite you don't have posi. With posi, you either won't be able to spin it or it will have some resistance.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
