700R4 suddenly lost drive/reverse
Old Aug 30, 2020 | 04:32 PM
Csp22uk's Avatar
Hi guys wonder if anyone can give me some pointers.
out of the blue today the car lost drive. If i select drive or reverse it just revs, the car does move a tiny bit but only just. There were no noises, no fluid loss.
i checked fluid level and it was at the lower range on the dipstick. Topped it up so it was full, but that still hasnt helped.
the only observation i had prior to this was that there was a hard thud each time going from
neutral to drive or reverse, changes seemed pretty good though.
anything i can check prior to removing the transmission to help try and diagnose ?
thanks
Old Aug 30, 2020 | 06:11 PM
Re: 700R4 suddenly lost drive/reverse
If the fluid level is right when running, and goes WAY up when not, then the pump is working.
Sounds like maybe the low-reverse clutch has retired in some way.
Old Aug 31, 2020 | 11:10 AM
bennettcvcu's Avatar
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
Check all the external mechanical linkages first. I had this happen before and it was an easy fix.
Hope you're able to figure it out.
-Chris
Old Aug 31, 2020 | 03:38 PM
OrangeBird's Avatar
Car: 1989 Firebird
A check of the transmission fluid pressure would give you a good troubleshooting starting point
Old Aug 31, 2020 | 11:19 PM
vorteciroc's Avatar
Top Answer: 1
Are you are saying that the Transmission does not operate in any of the gears?
Does the Park position keep the car from rolling away?
If the transmission does not move the vehicle in any of the gear ranges...
But the Park position does HOLD the car in place...
Then most likely the Oil-Pump or Torque-Converter are no longer working.
Installing a Line-Pressure gauge into the Test-Port on the Driver-side of the transmission (just rear of the bell-housing) will help diagnose.
No/ very low pressure on the gauge = The Oil-Pump is no longer working.
Good luck!
Old Aug 31, 2020 | 11:21 PM
vorteciroc's Avatar
Top Answer: 1
I forgot...
If the Park position does not hold the vehicle in place...
Then the output-shaft is most likely broken (or the rear-planet ring-gear)...
And I assume then, that you have been doing Neutral-Drops.
Old Sep 3, 2020 | 04:40 AM
Pro Built Automatics's Avatar
If it moves in first gear and has third gear, then the sunshell is gone. If the vehicle moves when in park, most likely the differential is the problem.
Vinscully50
Dec 31, 2016 09:10 AM
V6KILLER209
Apr 3, 2012 09:17 AM
soarestransam
Sep 28, 2011 07:12 PM
TPI TERR
Feb 8, 2007 06:54 AM
DocHoliday
Dec 12, 2006 04:30 PM
