getting speedo to read correctly
Old Oct 6, 2020 | 06:12 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
car I bought has the gta digital dash. The speedo reads randomly while driving and sometimes even drops to 0. I am guessing the speed sensor needs replacing. Rear gears are changed to 3.73 so what would I need to buy for the 700r4 to make it read correct speed? Is there a special sender or gear I need for the speedo that hooks into the trans?
Old Oct 6, 2020 | 06:21 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Re: getting speedo to read correctly
you will need a Digital Dakota SG1-5 to get your speedo reading acuratly with your rear gears. As far as the speedo bouncing around i recomend cleaning the connections to the digital dash. I mounted mine here on my digital dash
Old Oct 6, 2020 | 06:34 PM
msammy93's Avatar
Engine: 383 TPI
That is nice spot to mount that. Thanks for sharing!
Old Jan 4, 2021 | 04:08 PM
msammy93's Avatar
Engine: 383 TPI
Update: for anyone else with a bouncing speedo, I removed my cluster and cleaned the contacts with a brush and now it works fine.
Timothayyy
Jul 31, 2011 03:30 PM
1992camaroguy
Mar 4, 2009 03:14 PM
BlueZee28
Feb 28, 2007 10:36 PM
Riley's35089rs+
Sep 17, 2002 01:04 AM
