electric speed sensor ?
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I bought a 87 700r4..it has an electric speedo sensor. My car is equiped for the mechanical. Can I just swap the tailshaft housing and mechanical gear from a 84 700r4?
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Yes, but dont go the other way and try and use the electic speed sensor. My situation is the total opposite. I have a electic speedometer and a gear driven speedo gear. I put in a eletric speedo gear and if its pluged in and I go 10MPH the speedo jumps up to 120 then kills the engine. Explain that.....I cant I'm just going to autometer to get mechanical speedo equitment. As far as the correct gear I dont know which one you need but just be aware that there is more than 1. Call some trans shops and speedo shops and see if they can look that up by you telling them where the Trans came from and where the speedo came from. also search www.google.com for speedo shops and trans shops near you. This way you can get their phone #.
Engine: 406
Wow! Thats a crazy situation you have there. Thanks for the info and I'll take your advice and call around...I figured it would be ok, I just wasnt sure, Ive already Killed 2 700r4's. One more and I'm going th350-400. Thanks again.
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
BlackphantomZ28
Aug 22, 2015 01:00 PM
