10 bolt 3.73 gear whine
Old Nov 5, 2020 | 08:19 PM
gladback007's Avatar
I had a shop set up my new 3.73 gears on my gm 10 bolt and they gave me a few pictures of the pattern. They are telling me the whine is normal. I asked for a competition contact pattern. I don’t know much about gear patterns. What does everyone think about the pattern? Is it set up wrong or do I have another issue causing the noise?
Coast side
Drive side
posi is Yukon duragrip
gears are us gear 3.73
they used 80w90 standard gear oil and trans x limited slip additive
Old Nov 5, 2020 | 08:39 PM
Re: 10 bolt 3.73 gear whine
Pattern looks OK to me.
Whine is more likely to be the bearings. Not enough or too much preload. (probably, not enough) When is it worst; in drive, coast, or float?
Old Nov 5, 2020 | 08:44 PM
I’ll have to drive it again to confirm but I believe it is only noticeable during coasting.
Old Nov 5, 2020 | 08:58 PM
It is most noticeable coasting from 50mph down. There might be a slight wine when cruising at 50mph but I can’t differentiate that between road noise. The rear end only has about 25 miles on it.
I’m also getting a rubbing noise from maybe the posi when doing tight corners. I read on here that maybe I should get some more of that friction modifier. They said they used half a bottle of trans x which looks correct from what I read. (Whole container is for 4 quarts)
Old Nov 5, 2020 | 09:20 PM
NoEmissions84TA's Avatar
Pattern looks fine. Most of the numerically higher ratio gears will have a note in the instructions that say they will make some noise.
I have 4.10s and I used a special wheel in a Dremel to deburr the edges of every single tooth both ring and pinion gears.
I have no noise.
Billgluckman
Apr 5, 2020 08:06 PM
joeblue83
Nov 4, 2008 05:14 PM
SGT.ROCK
Aug 8, 2005 12:03 PM
chad89ta
Jun 2, 2004 07:20 PM
mdhoward@family
May 26, 2004 10:38 PM
