I'm new here
Old Mar 22, 2021 | 05:05 PM
Screminchicken's Avatar
I'm new here
I have recently acquired a 1988 formula firebird and at some point in life it has had a 400 small block and a 350 turbo tranny. The guage cluster is electric and someone has tried to run the cable before, does anybody know if there are analog to electric speedometer adapters. If I could tie it in to my original harness that would be awesome but I dont know if that is even a thing.
Old Mar 25, 2021 | 05:44 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: I'm new here
Yup you can buy analog (cable) to VSS (electronic) adapters from Dakota Digital and a few other online sources. There is also a speedometer sensor that will fit that trans that will put out the correct signal too. Check with a local transmission shop and they should be able to point you in the right direction.
Screminchicken
Mar 22, 2021 05:26 PM
Screminchicken
Mar 22, 2021 05:04 PM
TexasSilhouette
Interior Parts Wanted
Feb 3, 2013 11:29 PM
beckler
Mar 5, 2012 06:30 AM
MINN IROC-Z
Jun 23, 2002 03:51 PM
