TV Cable Problems
Old Mar 28, 2021 | 01:08 PM
NateMc24's Avatar
Car: 1985 Chevrolet Camaro
Engine: 355.00
Axle/Gears: 3.42?
TV Cable Problems
I recently bought a 700r4 kickdown bracket for my Holley Carb and now if I want to get to WOT the TV cable pops out of the slide because it is too short. I am wondering if there is any more hardware I need to get in order to reach the correct geometry. Here is a picture if you spot anything that I need to adjust or am missing please let me know. Help is much appreciated.
Old Mar 28, 2021 | 01:55 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: TV Cable Problems
Throttle cable is on top the TV cable is on the bottom....
Your TV cable cannot pop out if its properly seated
Your throttle cable looks like it missing a c clip to hold it in place
Old Mar 29, 2021 | 10:10 AM
dfarr67's Avatar
I used to mess with stock cables- went with Bow tie OD cable and latest spring, set to their psi- absolutely no issues. They will make a custom length cable too.
Old Jun 30, 2021 | 09:53 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
The cable housing where the tv valve link pulled up into is too short! Check out the post I just made.
Old Aug 6, 2021 | 11:58 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
The Bow Tie Overdrive bracket and cable mounts are the absolute best around. I have been using mine for years, and I had the good fortune to be stationed close enough to have them build the transmission, install and tune the whole set up at their shop in SoCal. The shift quality, durability, and progressive shifting pressure are unrivaled. Highly recommended.
Old Aug 7, 2021 | 08:58 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Maybe it's just me, but the bracket at the rear of the carb looks like it's set way to far back ; I don't think I've ever seen a TRV cable extended out that far.
For what it's worth,...... if your car was converted to a carb, you might need to get an actual factory V8 carb cable. All throttle cables were made specific for the engine used in the car.
Old Aug 7, 2021 | 06:55 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Need a longer TV cable. Find one about 2 inches longer.
Old May 12, 2024 | 01:15 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
running into this exact issue with a holley and the exact same cable bracket and geometry corrector. The cable I got was the 37.25" but it is doing exactly as pictured above. did you ever find the correct cable?
TylerSteez
Oct 1, 2019 12:19 AM
Chevy Iroc Z
Sep 24, 2016 07:13 PM
ammoblows
Carburetors
Aug 26, 2005 02:11 AM
