TV cable hook up problems!
Old Aug 24, 2005 | 10:23 AM
ammoblows's Avatar
Car: 1982 Z28 Indy Pace Car
Engine: 350 HO 4bbl
Transmission: TH350
Anyone out there able to help me with hooking up the TV cable on my CFI z28. I just switched the 305 out for a 4bbl 350, got the throttle done...just can't figure out the TV cable...NEED HELP! Thanks in advance gents.
Old Aug 24, 2005 | 10:27 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
what kinda carb ya got?
do you have the bracket for it?
Old Aug 24, 2005 | 10:52 AM
ammoblows's Avatar
Engine: 350 HO 4bbl
Transmission: TH350
I have a holley 600, I bought one of those aftermarket crome deals...it works for my gas pedal but not the tv cable! I don't know what to do. I do have the original bracket for it, just don't know hoe the thing mounts...it was disconnected when I go the car. Thanks
Old Aug 24, 2005 | 12:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
www.summitracing.com
Type "tv cable bracket" in the search field.
You can also go through the On-Line Store function, Air & Fuel Delivery department. I believe more will show up that way.
Old Aug 24, 2005 | 05:28 PM
ammoblows's Avatar
Engine: 350 HO 4bbl
Transmission: TH350
you are the man!
Old Aug 25, 2005 | 03:15 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
(LT1guy on Redraif' logon)
Ammoblows,
I just did a similar conversion on my 87 TA, and I used two Holley part #s to do it: 20-95, which is a gold anodized steel throttle cable/TV cable bracket designed to work with Holly carbs, and 20-121, which is a bracket that bolts to the throttle linkage to give the proper mounting point for the TV cable. I noticed you are in GA, and Barnett Performance in Atlanta stocks both pieces (that is where I got mine). you can call them at 800-533-1320, or drop by their showroom down in the 'hood on Memorial Drive (take I20 to Boulevard, go north, and take a left on Memorial...they are the big white warehouse with red yellow and blue stripes at the top of the hill on the left).
Old Aug 25, 2005 | 04:17 PM
ammoblows's Avatar
Engine: 350 HO 4bbl
Transmission: TH350
Thanks.
Old Aug 26, 2005 | 02:11 AM
yeah the cheap 20 dollar Spectre one isnt gonna cut it.......spend the 20 bucks on the holley one instead.
deracer
Apr 11, 2016 12:04 AM
Accerrito22
Aug 23, 2015 07:22 PM
92camaroJoe
Aug 13, 2015 06:07 AM
