lean @ cruse RPM
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
lean @ cruse RPM
pulled out my cam today and found the fuel pump lobe like this:
it's a Comp XR270HR cam... could that be causing problems?... dosen't look normal to me
Engine: 450HP 355
Transmission: TH350
Originally posted by Apeiron
Is something binding the pump lever?
i've never had any fuel pump issues.. just this lean condition at cruse RPM with this bigger carb i've been running... it got alot better with the bigger pump but it's still there...
Engine: 450HP 355
Transmission: TH350
nothing special, it's just a regular pushrod... i can pull it out and check in the morning though...
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I have an XR282HR, probably ground on the same core. I specifically asked them about the fuel pump pushrod and distributor gear, and they said that standard ones were fine on that core.
Engine: 450HP 355
Transmission: TH350
anyone wanna buy a low mileage XR270HR and run an electric fuel pump?
Engine: 450HP 355
Transmission: TH350
Which pump were you using?
Holley 110 GPH.. i only put about 100 miles on the car since the install of the pump too
BTW, how do you like your XR282HR ? Hows the idle?
Engine: 383 Carb
Transmission: 4L60
I'm kind of curious now about the internals of the pump. You wouldn't want to post a picture of it disassembled, would you?
Engine: 450HP 355
Transmission: TH350
i had to rotate it alot to fit..
