4L60/E 3-4 input drum Sonnax HD backing plates
Old Mar 29, 2021 | 10:17 AM
dfarr67's Avatar
In the current 700r4 I've had zero issues with the 3-4, and is not a racing application, K1500/towing/4x4. Decided not to go with Sonnax Smart Drum or 4L79 or variant for cost and custom parts availability. Will install Sonnax reinforcement kit- but was wondering what parameters are met with deciding to go with their HD backing plates vs GM 4L60E thicker backing plates? There's very little info in search and I think Sonnax make some great parts- but they like promoting them also.
Old Mar 31, 2021 | 02:26 PM
y5e06's Avatar
Car: itsa '85 LG4 S/E Turd 'Bird
Engine: Wheezy 305
Axle/Gears: 10Bolt, 3.42s, TruTrac
Re: 4L60/E 3-4 input drum Sonnax HD backing plates
I used these same parts. you have to use the 4L65 set of frictions which includes an extra friction vs 4l60. an extra friction is a good thing.
https://www.sonnax.com/parts/4544-he...king-plate-kit
Designed for use with GM high energy clutch pack with seven .067" frictions and six .095" steels, this kit can be used to upgrade OE 700-R4 and 4L60-E five-friction or six-friction clutch packs to seven frictions, or to improve stock, seven-friction clutch packs in 4L65-E and 4L70-E units by reducing backing plate flex.
i think i used GPZ clutch setup for 4L65E. ended up having to pick up a couple frictions in a thicker thickness to get the perfect stack (0.080? 0.105"?, don't recall exactly) Few bucks from local supply house.
this is in my OBS 4x4 4L60E and I use it for towing. I also used the reinforcement kit.
Old Mar 31, 2021 | 03:01 PM
dfarr67's Avatar
I guess they work.......until they don't
Been told that the thicker oem backing and apply plates will work well for my power- will use BW or GPZ in that clutch pack with the reinforcement kit as well. This is for a 89 K1500 which I'm slowing working towards a 24X 0411 conversion.
BOTTLEDZ28
Brakes
Jan 6, 2017 06:02 PM
chevymansmp790
Brakes
Apr 10, 2009 07:12 AM
bluegoose
Aug 17, 2006 06:53 AM
jeffsbluez
Oct 26, 2003 02:25 PM
