9-bolt disc on 10-bolt drum?
Old Oct 23, 2003 | 05:26 PM
jeffsbluez's Avatar
Car: 91 z28
Will this work or do I have to use 10 bolt backing plates? Oh, the 9-bolt is an 87 and the drum is 91. I have done a search but did not find the answer for this question. Thank you for any and all help-Jeff
Old Oct 24, 2003 | 05:39 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
First off, I wouldn't use the '87 disc brakes. Those calipers are prone to failing and not working right unless you install the recall kit in them, and by that time you might have well just installed the better '89-up PBR rear discs. All the rear disc brakes from '89-97 are essentially the same so there's lots of them out there. I wouldn't waste your time with the '87 brakes.
Ed
Old Oct 24, 2003 | 02:52 PM
jeffsbluez's Avatar
Car: 91 z28
Thank you for the reply. The backing plate for the 93-97 will fit my drum rear? If this is true you just made my life a lot easier. Thanks-Jeff
Old Oct 24, 2003 | 04:54 PM
ebmiller88's Avatar
Ah...there's the catch. NO, the 4th gen backing plates won't work, but you can still get 3rd gen backing plates from GM and all the rest will bolt right in. Contact Dal at VanDevere Olds and he'll hook you up.
Please note, you will have to do some brake line mods to get your current axle's lines to work, or spend $30-50 on new disc brake hard lines and be all set.
Ed
Old Oct 24, 2003 | 06:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Disc brake backing plates won't bolt on to the drum rear flanges.
Old Oct 25, 2003 | 05:29 AM
ebmiller88's Avatar
Oh yeah...I need to clear this up. The disc backing plates will work on the drum rear but you'd have to do a bit of modding to get them to fit. There's a tech article on a drum to disc swap on the home page so look into that. It's really nothing more than sawing off a little metal off the top of the axle flange and drilling a couple holes.
Thanks Apeiron.
Ed
Old Oct 26, 2003 | 12:40 PM
jeffsbluez's Avatar
Car: 91 z28
So what do I need to do to bolt on disc breakes to my drum rear?
Old Oct 26, 2003 | 01:42 PM
ebmiller88's Avatar
1. A brake setup
2. Disc backing plates for your rear (9 or 10 bolt)
3. New/different e-brake cables
4. Either get new axle hard lines or mod your own.
5. Tools
I know this link is for LS1 style rear brakes, but it's along the same lines of what you will need to do. It's on the home page.
https://www.thirdgen.org/newdesign/t...reardisc.shtml
Ed
Old Oct 26, 2003 | 02:25 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
if you need ten bolt disc backing plates i have a spare new set you can have for cheap.
you will need all the above metioned things.
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
