WHICH Flywheel do I have....
Old Jan 17, 2002 | 01:34 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
OK this might go in motor swap BUT you history guys know ALL..
I have an 82 Z28 with Borg warner 4 SPEED....
so do I have a "normal" 168 tooth flywheel?
as in any 1955-86ish block, crank etc.
The reason I ask is the 383 needs a "400" (externally balanced)
flywheel to work so, if I just buy say a Hays SFI aprroved 400 flywheel will it work, or what about one from GM for a 400? (169$)
THANKS FOR your help, DAVE
Old Jan 17, 2002 | 09:56 PM
87RS402's Avatar
IIRC you still have the 153 tooth wheel. The 4 speed was a T-4 im my memory serves me correctly and th only real difference between those and the T-4 is 5th gear.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
