transmission additive
Old Jan 17, 2002 | 05:59 PM
phisherness's Avatar
my 96 plymouth voyager's automatic transmission is slipping out of gear into neutral when still cold. When the car heats up it stops doing this. The dealer says that they have to completely rebuild the trans and it will cost around $2k. I really dont want to spend the money if i dont have to. I have heard of a special transmission additive to help with this problem. Does anyone know of any additives i could use?
Old Jan 18, 2002 | 04:10 AM
transfixleo's Avatar
Sorry but no it won't fix anything. What is happening in your tranny there are many internal leaks that add up and cause these complaints. I do allot of those units. Make sure that they use a TransGo Shift Kit and correct oil for this unit. Also, have a cooler (TruCool is the best) installed and bypss the radiator or it will likely drop again. This is because the converter clutch comes apart and restricts the radiators tranny cooler. In fact, I have a '95 Concorde I bought with similar problems. I am buying the converter from the dealer since I don't trust the reman units out there.
Old Jan 18, 2002 | 11:29 AM
thanks for your help
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
blackandblue02
Sep 10, 2015 08:19 PM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
