LT F-Body 4L80E Swap Writeup?
I posted on LS1Tech to see if anyone there would find this info helpful, but didn't get much response. I know you guys have a bunch of LT swapped cars, so maybe it would be more useful?
Is there any interest in a parts list/writeup for swapping a 4L80E into an LT car? When I was doing mine I found a few threads from guys with an Impala SS doing this, but there was practically no documentation for F-Body cars. Mine Specifically is a 4th-gen 94 Firebird Formula, but I would assume many of the parts/procedures would be very similar. Tho I have never worked on a 3rd gen myself, I've watched quite a few videos of others working on them, and it looks like all the areas of the car involved are the same if not very similar.
Re: LT F-Body 4L80E Swap Writeup?
I do not have a list of Part Numbers on hand at the moment, but...
There is not much involved.
This is a 1994 F-Body that has a Gen-2 SBC and a Early design 4L60E?
First off, the 1996 and earlier 4L80E Case fits slightly better than newer Cases.
This is because both Cooler-Lines are at the Bell-housing on the 1996 and earlier Cases.
Some room is needed to be made in the tunnel for the Electrical Connector... but not much.
Spohn, BMR, and UMI all offer a Cross-member for a 4L80E.
No Adapter, Crank-Spacer or special Flex-Plate is needed.
Use a Flex-Plate for a 1991 - 1997 G-Van with a Gen-1 SBC 350, and a 4L80E.
I am not certain which PCM Models would work for the Gen-2 SBC EFI/ Management.
Have fun!
Have fun!
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
For the 3rd gens you are own your own to buy a tunnel mounted torque arm or fab something yourself. I think the 4th gens have a crossmember / torque arm mount combo to buy. Other than that, the newer trans need some clearance for the rear-most fluid port and your are on your own for controlling the trans functions based on ecm. There are alot of old threads on this subject through the years.
Car: `86 SS / `87 SS
Some 4L80E models are really close in wiring to some 4L60E models. A tune is still needed, but with a little wiring work, and tuning, the same PCM can be used.
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
RockinGTA89
Mar 28, 2009 10:29 AM
