D.I.Y. Crossmember Mod for 700R4 to TH350 Swap
Old Nov 14, 2021 | 06:45 PM
tater's Avatar
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
I have seen many posts about people having this issue. I have not written a post because I didn’t have pictures until now. I did this simple mod 11 years ago on my daily driver. Since I was under my car this weekend installing a new aluminum transmission pan and temp sensor, I figured I would finally take some pictures. I made it from 1/4 inch plate steel. The attachment for the torque arm has several holes so I can easily change the pinion angle, although I never have.
Old Nov 14, 2021 | 06:59 PM
Re: D.I.Y. Crossmember Mod for 700R4 to TH350 Swap
The problem with that kind of setup is, it applies a torque to the original crossmember. Instead of a load in line with the bolts, straight up and down, the force is applied way out at the end of that plate, and it tries to twist the factory one right off of the "frame". The "frame" is already bad enough about cracking around those bolts; over any kind of long term or high mileage, something about that long lever arm would almost certainly fail, sooner or later. T-56 crossmembers do a similar thing. I've seen cracking in my car's "frame" there.
One of those things that's possibly OK in a static situation, but dynamically, it's problematic.
For a 350, much better to simply add the 2 front bolt holes that 82 had, and fab up something that mounts directly up there.
I do like your pinion angle / instant center thing though. As long as you can set it to where the pinion angle at an acceptable spot, at the same place that it the instant center needs to be, it should work pretty good.
Old Nov 15, 2021 | 01:07 PM
tater's Avatar
Transmission: TH350
I agree that it could be a problem in a high horsepower application. That's why I keep my power level nice and low.
Maybe I just got lucky, but, it's been working fine for 11 years.
Old Nov 15, 2021 | 04:18 PM
I wasn't really thinking so much of high horsepower; more, just driving on bumpy roads alot.
I'm glad it's working. Best of luck to you, that it continues to do so. It looks well thought out except for that one detail.
Old Nov 15, 2021 | 05:45 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I was looking at the mount and wondering that also. Is there front to rear movement of the torque arm, or more just up and down?
Nice fab work OP.
Old Nov 15, 2021 | 05:50 PM
vorteciroc's Avatar
Top Answer: 1
Don't Spohn and the other Suspension Companies produce a THM350-Swap Transmission Cross-Member?
Old Nov 15, 2021 | 06:18 PM
There is a very small amount of front-rear motion, therefore the stock rubber slider thing. Probably no more than a half-inch or so though. Most of the forces are up-down.
Old Nov 15, 2021 | 08:24 PM
vorteciroc's Avatar
Top Answer: 1
The Stock Torque-Arm definitely moves forwards and backwards inside of the Stock Mount.
However the amount of movement is very small... around 7/16" in each direction.
As the Rear Differential/ Rear Suspension compresses and extends...
the Torque-Arm must be able to move with the Rear-End (back and forth in the Mount).
83_Camaro_83
Mar 24, 2022 10:45 PM
UMI Performance
Jan 7, 2010 06:54 AM
shawn18jgr
Jul 30, 2005 08:07 AM
3.8TransAM
46
Jun 6, 2005 01:17 PM
TorchTA
May 10, 2005 03:12 PM
