non thirdgen tranny Q
Old Jan 18, 2002 | 12:48 AM
85 Berl's Avatar
i have an '81 GMC truck with a 350C trans. I have a couple of questions about it. First, I hooked up a tach last week, and I expected the cruise RPM's at 60mph to be 2500+/-, just from driving it and listening to the engine. The tach says 1800 RPM @60 with the TC locked up, and even at WOT the RPM's stay below 2300. It runs good, and has good power for a 2 barrel 305.
Does this cruise RPM sound right for a 1/2 ton pickup? The last one I had cruised at 3K (76 K5 Blazer), and I think the tach is right.
My other question has to do with the shift points of the tranny. I said earlier that it never revs over 2300 at WOT. That's fine, since it's matched to the 305's torque cam, but it's got a 350 in it's future that will want to rev a lot more than that. How can I Change the shift points at WOT?
Oh yeah... Has anybody used the Transgo kit for this transmission? What did you think?
Old Jan 18, 2002 | 12:51 AM
85 Berl's Avatar
One more thing... the tires are about 28 inches tall.
Old Jan 18, 2002 | 03:59 AM
transfixleo's Avatar
"Special Beater Edition" ROTFLMAO!!!
Anyways, if you have tall gears that would be about right with those tires. Let me ask you this: Does it 'feel' right? That is in simple terms what it should be like when shifting at the correct time for the combo a vehicle has. In the future if you need to raise the WOT points you will be looking at governor recalibration but I wouldn't mess with it until then. You also likely have a L/U which drops R's down too. Is there a wire going in on the drivers side, pointing up? That is it.
Old Jan 18, 2002 | 11:59 PM
85 Berl's Avatar
Yep, it has a lock up. I have it hooked up to a toggle switch. It feels right for the current combo. When I put the 350 in, I'll have a tranny shop mess with the shift points. Transfixleo, what do you think of the Transgo recalibration (?) kit for the 350C? Should I have a shop put it in, or would I come out better doing that myself? I don't have much experience with autos. I put a B&M (I know, screwed up) shift kit in the 700 in my camaro, and now it shifts very high (around 4000 if I play with the gas). I don't know if I screwed that up or if it was already like that.
Old Jan 19, 2002 | 09:08 AM
The 350C Reprogramming Kit is allot easier to install than the 700 and it has the exact same features of the 350 version, which took some work to accomplish. I remember talking to TransGo about whether they were going to come out with one but at the time they cited the declining sale of O/H kits for this unit that indicated not enough demand. I'm glad they changed their mind on this as if you want a 350 instead of an O/D, I think it is a good setup to use the 350C unit.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Thornburg
Aug 25, 2015 01:46 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
