97 trans am (v6) rear diff worth swapping...?
Old Jun 26, 2022 | 02:22 AM
88IROCZILLA's Avatar
Car: 88 camaro iroc
Engine: 5.0 TPI
Transmission: 5 spd mannual T5
Axle/Gears: 3.27/ 9 Bolt
I came across a 97 trans am (v6)(133,xxx) miles. With RPO codes Y87/GU6/G80 my currenct BW 9 bolt is making a "thumping" sound is 1st and 2nd gear although the car can still peel out with both tires (t5 transmission). Is this differential worth swapping for my 9 bolt?
Old Jul 3, 2022 | 12:46 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 97 trans am (v6) rear diff worth swapping...?
If you want the wider rear, sure.
MyNasty91
Feb 20, 2017 02:22 PM
Procharged GTA
Nov 24, 2009 07:53 PM
remltr
Oct 1, 2009 08:11 AM
badazz84camaro
May 6, 2008 11:17 PM
jimboc0
Mar 23, 2004 05:24 PM
