How to set pinion angle and what should it be?
Old Sep 20, 2009 | 10:30 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
I know you need angle of DS and angle of the rear. How do you calculate and what should it be set at? Suspension should be loaded when these measurements are taken? I have a UMI Adj TA and I need to set angle. Thanks.
Old Sep 20, 2009 | 10:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: How to set pinion angle and what should it be?
Put the angle finder on the driveshaft. Lets say it's pointing down to the rear 2*. You then need to find the angle of the pinion. There is no real easy way other than disconnecting the u-joint and putting the angle finder on the yoke.
Take off 90* to get a horizontal angle. Lets say the yoke is pointing down 1*. 1* down on the yoke plus 2* down at the rear of the driveshaft = 3* pinion down angle. The pinion angle is only in relation to the driveshaft and not the ground. You can have the rear sitting up on jackstands and still check the pinion angle.
Now for some reason you had some weird angles. The driveshaft is up at the rear 3*. The pinion is down 5*. 5 minus 3 = 2* down.
Now to properly do it, you first find the angle that the crankshaft is at and set the pinion angle to the same angle or 1-2* down, completely ignoring the angle of the driveshaft.
For the majority of street cars, 1-3* down is all you need.
Old Sep 21, 2009 | 06:52 AM
remltr's Avatar
So pinion angle is... angle of the DS + angle of the yoke. This number should fall between 1 and 3 degrees.
Old Sep 21, 2009 | 06:56 AM
big gear head's Avatar
http://www.iedls.com/IEDL_PTS_LGL_091008_Secure.pdf
http://www.iedls.com/guide.html
Here is some good information.
Old Sep 21, 2009 | 03:16 PM
remltr's Avatar
Read some of the info. So pinion angle should be 0? I've read that an F-body with a manual trans should be set between -2 to -3 degrees. Can you guys confirm the formula:
Angle of DS + angle of yoke? Should I confirm that the engine is at -3 degrees then go from there? Car has new poly motormounts and poly trans mount.
Old Sep 21, 2009 | 06:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Our coil suspension/ladder bar cars don't have the same windup as a leaf spring car. Pinion angle doesn't need to be extreme. Under hard acceleration, the pinion wants to rotate upward. The highest you want it to angle up at that point is 0*. The majority of all the third gens will do fine with a setting of 1-3* down angle.
I can't even remember what I set the pinion angle to on my 4-link. Something like 2-3*.
Old Oct 1, 2009 | 08:11 AM
remltr's Avatar
In theory, if I adjusted my TA so that the angle of the DS is the same as the angle of the pinion then adjusted it so the pinion is set 1-3 degrees less this would be ok?
evilstuie
Feb 28, 2016 03:33 PM
lt1z350
Sep 29, 2015 01:50 PM
hectre13
Aug 26, 2015 08:17 AM
89fast5oh
Aug 24, 2015 08:14 AM
89mulletbird
Aug 12, 2015 07:08 PM
