T-5 Adjustment Help
Old Jul 25, 2022 | 12:25 PM
leakyz28's Avatar
Car: 88 IROC-Z
Engine: 350 H.O. w/ 113 heads (SUM-8800)
Transmission: 700r4 stage 2 500hp
Axle/Gears: 2.73 Posi Yawn Fest
T-5 Adjustment Help
I recently bought an '83 z28 with a T-5 (mechanical clutch), the previous owner said that it got a brand new clutch a couple of years ago and was never used ever since. In order to put the car in gear I need to shove the clutch as far as it will go and use excessive pressure, otherwise it refuses to go in gear, I have no idea why this happens, it also makes a slight rubbing sound when the clutch pedal is being pushed more than halfway. Is the clutch garbage or does it need an adjustment, if so how can I adjust it? any insight would be wonderful, still new to these cars.
bbc632
May 4, 2014 08:27 AM
bbc632
Mar 24, 2014 05:51 PM
88FFCdunkel
Nov 14, 2009 03:36 PM
z28cmr83
Mar 27, 2005 08:23 AM
nidyanazo
Jan 16, 2005 10:27 PM
