lt1 t56
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: lt1 t56
I have a stock replacement set from Rock Auto with 4th gen pedals and a center force dual friction clutch. Works well but the engagement point is higher than I would like it to be.
Re: lt1 t56
So why the 4th gen pedal assembly? Why i ask is i just installed 3rd gen pedals into mine.
Car: `86 SS / `87 SS
Re: lt1 t56
The LT1 clutches can be tricky if there is too much, or too little slave cylinder movement.
Stock 4th gen pedals, hydraulics and clutch are a good match, obviously.
Using 3rd gen pedals with 4th gen hydro and clutch gives a little firmer pedal. And shortening the master pushed is one thing to consider when fine tuning the pedal travel / height to work "well."
Re: lt1 t56
the attachment stud for the master cylinder attachment is closer to the top on the 4th fen pedals.
Car: 84 Z-28 Camaro, 2022 Chevy 2500
Engine: 383
Re: lt1 t56
I used a stock 84-92 assy, pushed the roll pin out of the master, (the aluminum one that autozone sells/sold, not sure if they still sell it) and pushed the roll pin out of the smashed master that came with the T56 I got (slave was loosely attached to the bellhousing, it looks like the shipper dropped something on the master, possibly the transmission; trans, slave and line were fine)and re-connected the line to the 84-92 one and blead it, works great
Drifter92
Dec 12, 2013 05:22 PM
Jake88maro
Dec 20, 2011 08:21 AM
HuggerI-ROC
South Central Region
Nov 8, 2007 04:21 AM
