Stock t5 shifter lever, is there a clip between the fulcrum?
Old Oct 5, 2022 | 01:25 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
On a stock t5 shifter what holds these two pieces?
my brothers falls right off. I’ve never had one apart.
looks like there would be a spring clip or something. Maybe that is what is missing? Or is it just an interference fit?
Old Oct 5, 2022 | 01:28 PM
3rdgenmaro's Avatar
Car: 88 IROC
Re: Stock t5 shifter lever, is there a clip between the fulcrum?
What it should look like
At my mouse pointer, what keeps this joint together?
Old Oct 5, 2022 | 01:42 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I have never seen one apart or even found a write up of how to separate them. It looks like a friction coupling similar to what holds the chuck in place on a drill press, which would make sense when you think about the assembly process.
Have you tried putting it on and giving it a good tap with a mallet?
Old Oct 5, 2022 | 03:01 PM
3rdgenmaro's Avatar
Car: 88 IROC
I know what you are talking about. Those big bits with the interference fit (probably wrong word for this one) and have to edge them out. Guess those are more a taper those
that must be all it is. Seems to be holding so far. Thanks
Old Oct 6, 2022 | 10:13 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
It's either a threaded joint, or a press-fit rubber bushed joint, depending on original application.
85Iroc-Z
Jul 28, 2010 08:44 AM
ctandc
Apr 6, 2003 08:31 PM
