torque wrench inch pounds
Old Oct 27, 2022 | 03:32 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
I will be replacing the bearings in the rear end in the near future. I need a torque wrench in inch pounds to check the pinion bearings. Would this on do or do I need to spend $250?
https://www.summitracing.com/parts/wmr-m195
Old Oct 27, 2022 | 03:56 PM
Re: torque wrench inch pounds
Should be perfectly fine. MUCH better than a "clicker" for example.
Old Oct 27, 2022 | 04:36 PM
J.C. Denton's Avatar
Car: 85 Iron Duke, 88 GTA and 92 TA
I have the exact same one and it works perfectly.
Old Oct 31, 2022 | 02:08 PM
69-er's Avatar
That's the standard issue when it comes to measuring preload. I agree, I can't imagine a clicker wrench working.
Old Oct 31, 2022 | 04:50 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Yep, that's the one I used. Worked perfectly.
FJA1791
May 1, 2015 06:55 PM
camaromike222
Jul 16, 2010 09:10 AM
UK-1991-Z28
Aug 6, 2009 06:03 PM
Orinackra
Jun 7, 2008 12:57 AM
Sonix
Aftermarket Product Review
Aug 18, 2007 12:03 AM
