700-R4 Swap to 2nd Gen!
Old Jan 20, 2002 | 08:56 PM
87POSGTA's Avatar
Car: 1989 Firebird
Engine: 5.7 Vortec HSR
Axle/Gears: 9-bolt 3.45
well, my motor went on my other 87 I own about a year ago & the car has been sitting ever since. Now i had to get rid of the car and i gave my trans to my friend who owns an 81 Camaro with a TH-350. hes swapping it out and i dont want him to **** it up cause im makin a big investment here. the problem is that i have an Elec Speedo and he has a cable driven. I need to know if we would be able to buy a conversion kit to have the 700-R4 use a cable speedo cause if he screws up the trans im gonna stab him. i need any info on this swap i can get. links, books, posts, magazines. pretty much anything i can get. thanks in advance.
Old Jan 20, 2002 | 09:31 PM
Jay 727's Avatar
Just go to a junkyard or a trans shop and get the drive and driven gears, and sleeve for a mech speedo. it'll all bolt right in. You need to know what the tooth count needs to be for the peticular rear end gear ratio and tire size. they have a chart here
http://www.tciauto.com
Here is a direct link to the speedo gear page
http://www.tciauto.com/tech_info/speedo_gears.htm
Put your info in the boxes down the page.
Old Jan 22, 2002 | 05:07 PM
ChevyRacer83's Avatar
Hey Let me know how that swap works out! I have an 83 700R4 out of a Camaro and I wanted to put it in my 2nd Gen 77 Firebird. Right now I'm trying to find what shifter to use since the original TH-400 was a 3-speed and the 700R4 is a 4-speed.
Old Jan 22, 2002 | 08:58 PM
87POSGTA's Avatar
Car: 1989 Firebird
well i gave him the shifter with it also. but he picked up a console megashifter i think.?? tomorrow is the day we doit. Jay727 thanks man we got what he needed. I'll keep u updated ChevyRacer83 tell ya how it all works out.
Old Jan 22, 2002 | 09:14 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
87, you might also want to take a look at this site. http://smokemup.com/tech/transmission/700r4/700r4.cfm
They have the wiring diagram to hook up the tq converter lockup if you scroll down a few lines.
Does your friends car have a dual bolt pattern flywheel??? If not you may need to replace it but most likely it is dual pattern.
Good Luck with the swap!
SSC
Old Jan 26, 2002 | 12:43 AM
87POSGTA's Avatar
Car: 1989 Firebird
hey, well here's the update. 3" off the drive shaft move the crossmember back 3" and it all works out fine. only little hang-up were havin is connecting the TV cable to the carb. goin to the pick-a-part tomorrow mornin to pick up the little stud from a 3rd gen witha carb since my friend lost his. if ur running full length headers its a bitch tryin to get the tranny cooler lines back on the tranny. guess thats about it. pretty straightforward swap after gettin the B&M Megashifter for 70-81 ( can be used with a 4 speed after removing a pin and 2 c-clips) and the Painless wiring for the TC lock-up. seems u need to plug one of the valve bodies with a fitting. picked it up at pep boys other ones u can just leave the other 2 but we opted to plug them off too instead of just leaving the connectors/sensors or whatever they are in there since they wont be used.
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
