New Clutch, high bite
Old Feb 28, 2023 | 12:51 PM
Chemino325's Avatar
Car: 1985 Pontiac Trans Am
Engine: Carb. H.O. 305
Transmission: 5 spd
Hi all! Have a 1985 HO Trans Am with a T5. Recently the clutch disintegrated and I replaced the clutch, pressure plate, bearing, and fork.
The brand-new clutch grabs great but doesn't bite until about 7/8ths of the way up the pedal travel. Even with the old worn clutch, it would at least grab around 3/4ths of the way up.
I've heard about people using spacers to adjust the bite point because of the hydraulic clutch but I am not sure how to do this. Could I get some advice on anything I could do with this issue?
I'm worried this will cause big issues down the line when the clutch starts wearing out a bit.
I used the mpact clutch kit from rockauto
Thank you!
Old Apr 9, 2023 | 08:14 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
Re: New Clutch, high bite
Thank you!
Did you find out anything on this problem my son 82 Camaro Z28 is doing the same thing
Old Apr 10, 2023 | 09:08 AM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
An 82 has a mechanical clutch. Climb under the car and adjust it to where you want it. 82-83 have the old school setup, not the hydraulic/self adjusting ones.
SheldonZ28
May 28, 2009 05:05 PM
TBI92Camaro
Dec 21, 2006 05:43 PM
Lopezzi
Feb 13, 2002 03:17 AM
