700R4 question: TV plunger behavior
Old May 11, 2023 | 12:07 PM
ericj205's Avatar
My application is a small block 350 (vortec heads, Comp XE268 cam, Edelbrock 1406 carb. Carb has the Edelbrock TV corrector plate attached and TV bracket positions the cable horizontal and in-line with the TV cable stud on the carb. In other words, I feel like I have the bracket/geometry correct.
I am in the process of installing a 700R4. Before startup I had the pan off to try to ensure I was getting the TV cable adjusted correctly. After the WOT ratcheting out I was getting a slight amount of play between the TV lever/cam and the TV plunger. I noticed that the TV plunger did not fully extend when there was play between the lever and the plunger. I could move it further outward from the TV bushing and valve body. Is this normal? I took a short video to show in more detail. Hope this link works:
https://youtube.com/shorts/tUQDXCwBRk8?feature=share
Thanks!
Old May 11, 2023 | 02:21 PM
Re: 700R4 question: TV plunger behavior
There's a bit of pressure on all the parts in there with the engine running, so that's pretty normal. The plunger will get pushed out in actual operation.
Old May 12, 2023 | 02:29 AM
vorteciroc's Avatar
Top Answer: 1
What is shown in the Video does not concern me too much as long as the Spring-Pressure from that point then further Inwards...
Is nice and Firm.
If this is not the situation, report back...
A Firmer Spring may be required.
NOTE: Too Firm of a Spring will cause unwanted behavior/ problems.
z28nate
Sep 29, 2011 11:30 PM
ULTM8Z
Sep 11, 2011 08:38 PM
FF400
Oct 19, 2008 12:26 PM
TBICamaro
Dec 21, 2000 08:23 PM
