how much HP is the stock rear good for
Old Jan 21, 2002 | 02:35 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Im planning an engine build up with my new Supercharger (D1SC) and am aiming at about 450-550 HP, but im worried about the rear, how much is it good for, or should i just get a better unit altogether, also did the z's get posi track rear ends, or do i have limited slip ?
Old Jan 21, 2002 | 03:03 PM
ede's Avatar
ede
only differance in posi and limited slip is the spelling, they're the same thing. a 9 inch would be nice and maybe needed, but a lot of people have had 10 bolts live behind some strong engines, and others have broke them the first time out. i had a 10 bolt last in my sons camaro and i dropped a pretty strong engine in it.
Old Jan 21, 2002 | 04:08 PM
MouseCamaro305's Avatar
actually, theres really no set HP as to what a stock rear end can handle, some people have luck dropping a whole new setup, with excessive power, and some people can break them with the stock motor. Personally, like anything, l think it depends upon how well you treat it, if you maintain its fluid, if you avoid abusing it, and if you have a pretty realistic expectation as to how much power it can handle. My SC's rearend is basically stock, aside from a posi unit l installed. so far its gone thousands of miles, and over 20 1/4 mile passes with a ZZ4 (355 fw HP, and 405 ft lbs) and its running like brand new.
customblackbird
Aug 15, 2021 10:16 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
draco
Oct 4, 2015 09:25 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
